Dan you are a smart man leaving the rig behind, I read your sig! If you haven't gotten a hold of Bill try this. I'm going to assume that you have the variable resistor installed at the PCM, if not no big deal. Read the wire from the resistor to the harness, the voltage with the key on should be around 4. 4-4. 5 volts with a multi-meter, if it is high 5. 0 or low 3. 9 it will cause a fail safe start if the voltage is 4. 3-4. 4 there is probably a failed sensor (input or output) and the transmission is telling the PCM there is something wrong so it's trying not to leave you stranded, also I've heard real low fluid level can cause this but I can't conform it.
P. S. Mine did this at 4. 4 volts and I have to install an additional 50 Ohm resistor to get it down to 4. 0-4. 1.
Jim
Oh you should be able to pull it into Manual 2nd
