The lower the setting & still have a clean weld , less if inside with no air to blow away the gas , inside of conner - what your welding .
More gas if outside - tube / conner , near fan or out side with wind blowing .
The idea being to save on gas costs & have a good weld , you may , under the right conditions use just a couple lbs , if you have to weld in bad conditions , outside in the wind , you may have to go to 40 + lbs , then some conditions require different gases .
