I want to put in a line lock for doing burn outs. I would like to be able to block off the rear brakes and still have full front brakes. What do you guy suggest?
grrrrr why cant i edit the heading?????????????????
Fixed it for you. Do you have 4 wheel ABS or just rear wheel ABS?
Is it really that hard to do burn outs with 4 wheel ABS? Is there a lack of power?
Someone talked about doing that with a roll control and mounting it in reverse but I don't know if he ever actually tried it. I tried searching and was unable to find it. Problem I think you'd run into doing that is that the solenoid is designed to have the pressure on a specific side I'm pretty sure. They are designed to have the pressure applied and then the solenoid activated to hold the pressure on the other side of the valve. I'm not sure how they'd handle blocking the line and then having pressure applied to them. You'd have to contact one of the manufacturers to see what they have to say about it or just give it a try.
Unless your talking about a manual valve that you'd get out and throw - in that case you'd have to find a valve that can deal with the kind of pressures your dealing with in a hydraulic brake system and not leak. Mico makes manual locks like that but that are designed to work the same way the line locks are - here is the address for Mico: MICO, Inc. : Products/Literature . You could ask them if they have anything that would work that way.
