Engine/Transmission (1994 - 1998) Line Retorque Sequence
Engine/Transmission (1998.5 - 2002) Glacier-392
I personally start at the right front corner, go to the rear and come back up the next row over and so on. I don't know if this is optimal or not but it's holding and I don't have any problems that I know of.
It should be retorqued to 150lbs, correct? Also, to clarify, I would like to retorque the studs to the same torque. I believe it was 150, but I'm not sure. Scheid put the head/studs on originally. What do they usually torque the 14mm's to?
