2nd Gen Non-Engine/Transmission Line Sheet for 1996 2500 4x2
2nd Gen Non-Engine/Transmission from 17" to 18" wheel yes or no
Engine/Transmission (1994 - 1998) OK to drive w/AFC cover off?
Budro
I am looking to find a way to get the factory 'Line Sheet' for my 96 2500 4x2 I have checked with the local Dodge dealer, and pulled it up to look up the differental numbers, but he would not let me have a copy. Is there any other way to get a copy?
Also, The "Air Bag" light is on and I have not found a way to get it to go off. All fuses show good, but don't know enough about it to get very deep in the electronics of the system. Don't want to activate the air bag!
96 2500, 4x2, 5sp, 377K, Isspro EGT and Boost gages, otherwise stock.
JJones
You will need a scanner to diagnose the airbag system. The dealer can give you a copy if they want... ..... try the parts dept next time you go in to buy some parts ;)
Your dealer's service department is being an ***. Most are happy to print you a copy. You can always e-mail Chrysler customer service with your VIN and they'll mail you a copy.
Thanks for the info. I was thinking the same thing that a dealer should be able to print the linesheet. I haven't had much luck with the local dealer on other thing anyway.
Thanks again for the reply.
JJones
