Guys, allow me to clear things up. No pun intended:-laf :-laf :-laf
During the past several weeks I have been BoMBing my truck. I'll need to update my sig soon. Anyhow, this is what I have done;
4 inch exhaust,16cm,ASA intake w/ aFe, port/polished exhaust manifold,three turns on the fuel screw, POD's, timing advanced to 3/16 inch.
The truck runs like a scared rabbit,BUT... ... ... ... ... ... ... ... ... ..... I can't make smoke ,,,,, boost,,,,, or exhaust heat
So, this is what I've done; turned the engine rpm's up,made sure the control cone is turned to max taper,removed the star wheel [which really looks like a gear] to decrease the amount of spring tension. Faster fueling. Nothing worked. No smoke. I get a gray haze at take-off. Had that with the "stock" truck.
The only way I can make any smoke is to hold the brakes on,put her in drive, then mash the throttle to floor board. The rear wheels light up,the trubo goes into orbit and I can send smoke signals to the nearest town.
The object of my BoMBing is to gain a nice plume of smoke when I accelerate from a stop. Now this is the important part... ... ... ... ... ... . In attempt to play my last hand, I removed the coil spring from the AFC housing. Pastor Bob said this will make for lots of smoke at low boost. Well,,,,,,,,,,,,,It didn't
I'm gonna test for intake system leaks, but I believe my pump isn't "putting out"
BTW, my MAX boost is 24 with 950* on pyro, foot to floor, when climbing a long hill on interstate, empty.
Scott
