2nd Gen Non-Engine/Transmission LMC headlight harness question
Engine/Transmission (1998.5 - 2002) hx40 question
2nd Gen Non-Engine/Transmission Hi Idle
So, I got my LMC headlight harness to replace my failed SUVLights harnesses.
Ok the two part numbers distinguish between usage for the 9004 and the 9007 lamps. The 9007 lamp uses the harness 55-9506. The part 55-9505 is used for the 9004 lamp... ... . I've got that.
The problem, you ask???? Well the harnesses became separated from their packaging. The only difference between the two harnesses is the color of the lamp socket and a loop of wire between the relays.
So the question is... . which part number has the black sockets and which has the blue sockets?
Thanks in advance (for not laughing too much).
Thats a shame the suvlights harness didnt work out. I got that harness for the 99 when I did the conversion,It was pricey but seemed well made. Anyways, I dont think it would hurt to do trial and error. When I installed mine, I of course did it backwards, the lights were worse than before as far as brightness. Got home and reversed it and it was fine.
Volsfan, thanks. I was trying to avoid ripping my hands up further and just do the swap (if needed) one last time. There's isn't much room to maneuver in there. I was hoping someone would be able to direct me so that I can do it just once.
Anyone?
