Darn gemlins are taking up residence under the hood again. Everything was fine the first things this morning then an hour later nothing in the odometer and gear position display. Not just those displays either, everi light that is usually on on start up is not reponding including blinkers and high beam. The only light that come on with a cluster test is the red one in the lower right hand corner which I think is the security notification which is not on this truck.
Every function the is shown still works. Cruise, TH, CEL, etc, but won't display. All the normal things like batteries, cables, grounds, etc, have already been done. Bus connector on the firewall cleaned and reset. ECU rebooted. Truck runs and starts fine and all the peripheral things still work. Smarty shows no codes and will show a code that should used to generate a CEL.
Any similar symptoms and solutions out there?
