Engine/Transmission (1998.5 - 2002) location of apps connector
where is the connector for the apps located? I am trying to do the suncoast converter rewire to stop the lock and unlock thing on my truck. thanks
you have to take the black cover off the "bell housing" where your throttle cable is. There are 4 bolts you have to remove and the tps is on the back side of the spring and cable assembly.
If it is the connector itself you are looking for, it is located directly under the APPS. You have to reach under there and you can feel it, follow the wires up to it.
