How do you check/reset the apps?? thanks
The simple and quick way to test the basic functioning of the APPS is as follows:
1. Completely remove the APPS assembly from the engine. You'll be able to disconnect the TPS (Throttle Position Sensor) wiring harness hidden behind the APPS when you unbolt it from the engine.
2. Using an inexpensive ANALOG multimeter (one with a needle... not a digital model), measure the resistance (Ohms) between pins 3 and 5 of on the TPS connector as you SLOWLY open and close the accelerator linkage on the APPS assembly. If the TPS is working properly, you should see a smooth sweep of the needle on the multimeter from about 2300 Ohms when closed, dropping down to about 850 Ohms when open. The exact starting and ending resistance doesn't matter. The important thing is that you observe smooth movement of the needle on the multimeter. If the needle jumps around or hesitates as you move the APPS linkage, then the TPS needs to be replaced.
3. Measure the resistance between pins 4 and 5 on the TPS connector. You should see about 2200 Ohms and this reading should not change when you open or close the APPS linkage. The exact reading isn't critical so long as the needle on the multimeter doesn't move.
4. Measure the resistance between pins 1 and 6 on the TPS connector. With the APPS linkage CLOSED, you should have a closed (completed) circuit showing no resistance. With the APPS linkage OPEN, you should have an open (incomplete) circuit showing infinite resistance.
5. Measure the resistance between pins 1 and 2 on the TPS connector. With the APPS linkage OPEN, you should have a closed (completed) circuit showing no resistance. With the APPS linkage CLOSED, you should have an open (incomplete) circuit showing infinite resistance. Note how this is exactly the opposite of step 4 above.
If the TPS passes the above tests, it's probably fine and can be reinstalled. There are more accurate tests and adjustments that can be done with the APPS installed on and connected to the engine, but the above simple tests will reveal any major problem that could cause a runaway throttle condition.
To "reset" the APPS (which is actually reteaching the TPS voltage range to the ECM):
1. Disconnect both of the trucks batteries and turn the headlight switch on. Leave it this way for 10 minutes or so. This helps drain the memory from the ECM and PCM.
2. Turn the headlight switch off and reconnect the batteries.
3. WITHOUT STARTING THE ENGINE, turn the ignition key to the run position.
4. SLOWLY depress the accelerator pedal to the full down position and then slowly release it back to the full up position.
5. Turn the ignition key off.
You're done!
