Looking for 2001 Factory Service Manual info, can someone please fax it to me?
6BTA cylinder head pics
What Trany to pick...
I recently bought a Limited Slip Differential out of a 2001 2500 HO(thanks Okie!). It is a bit different from the '94 Dana 80 and will require a different set of instructions so I can overhaul it. Can someone please fax it to me? E-mail me at -- email address removed -- if you can help.
Thank You!
Disassembly & assembly of the carrier assembly. Also, inspection proceedure.
The '94 carrier (according to the manual) had almost one whole side open and was assembled through that opening. The new one does not have a hole so the proceedure must be different.
There is about 4 or 5 (I'm guessing) pages of the FSM that covers it. I'd appreciate it if someone could fax it (or scan and e-mail) it to me.
Thanks to nps and Texas Diesel for the assistance but I got it from the dealer last night.
Not much information and looks like it was written by a 4th grader. :rolleyes:
I figured they would have some dimensions to check to determine the plate wear but all it says is that if the plates appear to be worn, replace them. :rolleyes: :rolleyes:
Thanks Guys!
