Archived Looking for 3rd gen injectors
Archived Emergency! alternator not charging
Archived Black Oil
Spent the winter in wyoming doing a welding job. The company that I worked for was plagued with fuel problems on the job, both gas and diesel. I had my transfer pump go out on me and thought that I had got lucky but now 800 miles later my truck is smoking and losing power I have a good idea that Injectors are going bad. looking for anybody who would have pulled some out to replace. What tools and maybe part numbers. Any help would be great
04. 5 2500 no chips no gauges stock
no special tools are needed to remove the injectors. If you need any help, give me a call tomorrow at 240-818-2973 and I will try to talk you through the process.
Does anyone have the torque specs for the exhaust valves on 04. 5
???hmm???? :confused: tq specs on the valves? Do you mean valve lash clearance? If so, it is . 020" on the exhaust and . 010" on the intake. Torque specs on the rocker arm hold down bolts are 27 ft lbs.
Sorry about the clarity, I dont really have a book for this truck on all the specs. It just come off warranty a little bit ago until now I've let Dodge worry about the details. Thanks for the help
