looking for 5.7 Cummins interchange info
I wound up owning a 2005 pick up with a rod thru the block also the turbo and pump are missing. In an attempt to locate an entire motor I learned only 04-05 are listed as a drop in.
Checking further the factory shows the part number for a remaned long block assy, and it shows only fitting 04-05 yet if you pull the short block pn it fit’s 04-08 I guess it’s something in the head.
Can anyone give me more info what the differences would be with 06-08 and why they won't work should a complete engine be found.
