Looking for any information on 1 ton single rear wheel 4x4 regular cab
1992 6.5TD Rescue
cab fresh filter kit
8 ft box Cummins with Manuel transmission. What years did they make them?Do they still make them?I looked on new dodge websites but can't find any real information. But I might be in the market for good used-stock unit also. Have 1999 now
They are listed in the 2017 brochure.
They started in 2003 and are still made today.
From 2003-2009 the differences between a 2500 and 3500 SRW were very small, with the only real difference being overloads on the rear springs... overloads that really don't do anything withing the weight capacity of 17" tires. From 2009-2013 the rear spring pack was different with the 3500 SRW's having a 7% stiffer spring pack.
In 2013+ the rear suspension is completely different. The 2500 uses a 5-link coil setup and the 3500 SRW has a leaf spring setup.
I think the OP's question was mostly directed at a 3500 SRW (Standard/Regular cab). I think they were/are made, just that they seem really rare. I hardly ever see a regular cab in any pickup anymore.
Nick
Nick
Yes they are still made and very rare.
I figured I'd let him know the differences since they are hard to find. Up thru 2013 there isn't much benefit to a 3500.
Some good info, thanks. I would like to have a 4th gen someday or maybe 5th when the are used and old:)
Nick
Not THRU 2013, through 2012. The 2013 3500 SRW uses the new type heavier frame, 7000 lb rear axle, 6000 lb front axle (4x4), and has 11,700 gvw in short bed, 12,300 lb. gvw in long bed. It also has the 275-70-18 tires rated 3640 lb. The 2013 2500 had the old style frame, etc.
