I took down my power steering pump, removed the internal components pressed out the shaft the the rotor came out & the pressure plate came out in two pieces. Before I even started working on the unit while I was looking for vacuum pump bracket seal & O ring. While doing that I was spinning the shaft & I noticed that the pressure plate moved in a weird way, it looked like a two piece pressure plate. I was right, it is a two piece but it was broken. It was an old break cause the cast iron break was oil saturated.
So I am in need of a pressure plate if anyone has a Saginaw power steering pump off my 91 1/2 Cummins.
If anyone has a junk pump please let me know or if you have parts to one.
Thank you all.
Doug
Thank you all.
Doug
