Looking for pacbrake deal on brake and airbags
American Axle Limited Slip with photos
Turbo going bad?
Anyone know if there are any deals out there on an exhaust brake and rear air bag combination "kit"? Should I buy the air compressor from pacbrake or source my own?
I'm looking for a set up that (obviously) works well, but also has a clean install. I don't care for too many non-matching gauges and switches in the cab.
Thanks!
Scooby-I just purchased the complete set up from Diesel performance accessories for Dodge Cummins, Ford Powerstroke, Chevy Duramax. I have the Air Springs, PacBrake, compressor, tank, in cab controler switch & the accessory kit. I installed the in-cab switch under the drivers seat (facing the door) because it is too big to install under the dash.
The installation is simple. Just take your time and route wires & plastic hoses in plastic split looms--makes for a clean install & also protects the wire & hoses. I used isolation mounts on the compressor to quiet it down (I installed it under the bed on the passenger side because I did not want it under the hood). Another good idea is to install a switch (to ground wire from relay) to turn the entire system on or off. I did this because the compressor turns on with the ignition switch each morning to recharge the tank & the compressor is a bit noisey with the key "on" only.
The PacBrake works great as do the AirSprings.
HJR
Scooby, I bought the whole PRXB kit for my truck and it was real complete. I mounted the switch on my shifter. It is real handy there.
