Looking for pictures of 3rd gen's with stacks.
Can anyone beat Summits price on D25s?
Should I buy these?
Scrappy,
Are those 60" x 5" stacks? Also see that you have gauges. Did you notice higher egt's by going with the square tube instead of the standard exhaust tubing or did they stay about the same? I know that they are alot easier to mount and appear to be a stronger base for the stacks. Just curious about the flow of flat 90* turns...
stacks
the stacks were 5' by 48" with about 8" cut off, I don't like them sticking too far above the cab. the tube is 5"od but the flow is split to both sides. I don't think a 3. 5 downpipe will outflow the square tube. I didn't have gauges at that point so I can't tell if I had an EGT reduction.
