Looking for VA C3 Dyno info
My emergency brake cable is gonna get SQUISHED
This Friggin Truck
Does someone have the dyno numbers for the VA C3-L2 and the VA C3-L1. I am most interested in improving my low RPM (1400-1700 RPM) towing performance. But it would be nice to spank some other vehicles occasionally. I defiantly want an in cab adjustable box. Thanks.
If you have not bought yet then I would go for the L2. I bought the L1 and really like it especially for towing but even with it on the #3 setting I can tell that it kind of flattens out in the upper rpms when empty.
I am sure they do that to control EGT's. It shines 1400 to 1800 real well but actually makes noticeable more power over even a broader range, just not that much on top.
I may upgrade to the L2 and suspect that #2 setting would be good to tow with while the #3 setting would be a kick to use when empty for a spank or two!
Thanks for the link. Very interesting info. The L2 box looks real good for pulling. The graph is obviously showing "corrected" numbers considering the "stock" was 306. 1 HP & 580. 9 Lbs. Not bad for a 305/555. I would really like to see some dyno #'s from a TST PMCR on settings 3/3 & 4/4.
