ok guys lets start from the top, about 2 weeks ago, i put a FASS fuel system on my truck, i did not disconnect the battiers, i really didnt think i needed to, but i guess i should have, anyway, went to start the truck, truck was just cranking, no start, though maybe some air in the line, cracked a few lines loose, no fuel, i checked the solenoid to see if it is pulling up, it was not pulling up, i tap on the relay that controls the solenoid, it pulls up, but it does it violently, at first i didnt think that was right, it kept doing that, and then it finally pulled up on it's own, soo i decided to drive the truck home, and i was going to replace the relay, soo im driving home, and i hear a loud click from the engine compartment, first though was the solenoid was acting up or something, then i notice a loss of power, and smoke coming out from underneath the truck, great the solenoid is bruning up, so i pull over as quickly as i can, the solenoid is toast, after it cooled down, i took it off and zip tied the run lever up to get home, while driving i noticed that i had no tach, spedometer, and the truck was not charging, i was hoping that it was just somethng to do with the solenoid and the relays being bad, i replaced the solenoid, and both relays, and still had a no start issuse, it didnt occur to me about the blue fusible link, i check that, sure enough i was burnt, sooo i replaced the link, still the solenoid is not pulling up when i crank the engine, soo i did some reading, basically come to the conclusion that it is either the crank position sensor, or i took out the PCM, i replaced the crank sensor, still have no solenoid pull. ok now my question, is thee soemthing else on gods good green earth that i am missing, or did i really fry the PCM, is there anything else i can be checking to see if it is wrong. thanks for your help guys, im stumped on this one, and getting frustrated.
wes
sorry for the longggg post:-laf
wes
