Looks like I found my 12V
Ford Conversion
E Brake on 4BT/4BTA
Thanks to Harvey at J&H performance. It's a '98, federal emissions 180hp motor. :) Probably going to o-ring and stud the head before I install it in my truck, then let the BOMBing begin. If I can keep to my schedule I should have it in my truck by late April or early May. Oo.
Don't forget the KDP, I'm sure there's plenty other things one should/can do while the motor is out. Someone else can chime in on that.
I plan on making sure the kdp is taken care of also the bolts inside the front cover, and anything else I can see. The engine is going to be run on a test stand so I should have a fairly good idea of any problems such as oil leaks and such.
