Competition Looks Like Piers isn't the only one with a Blower....Ford boys doing it too
Competition Southern Idaho Pull
Competition GM Trucks and pulling???
Dude... sounds like he is ****** in his description. For self-fabrication like the guy claims, it looks pretty clean especially for an engine that looks like it has to be put in with a shoe horn.
Scott
HMMmmm - depending on the actual displacement of that supercharger, it would sure seem that while it could be good at low/midrange operation, it could be a bottleneck at high flow due to being AHEAD of the turbo, choking it's flow capability...
Interesting - but sure must require lots of engine mods for the V8 diesels to live with...
"95-2005 7. 3 LITER BOLT-ON SUPERCHARGER KIT. ALLOWS QUICKER ENGINE RESPONSE,BETTER FUEL ECONOMY UNDER CRUISE CONDITIONS, USES STOCK BELT. CONVERTS ENGINE TO SEQUENTIAL(2 STAGE)SUPERCHARGING WHICH ALLOWS MANIFOLD PRESSURES UP TO 60 PSI"
What part of this is nonsense?
Someone is missing the fact that the 6. 0 PSD has a variable turbo. :rolleyes:
Won't work and if you stop and think about it no one out there in the automotive world has bothered to do it. Reason -
1. Parasitic loss of the blower makes it problematic. This could certainly be overcome but... ...
2. If the blower is working properly it would likely cause surging in the turbo (stalling the air flow) and actually increase back pressure negating any boost effect of the turbo. Because the blower is a positive displacement pump the turbo never stands a chance to overcome the blowers push. The turbo then becomes the choke point in the exhaust system.
3. There's a reason manufacturer's chose turbo's over blowers on diesels. The turbo's spool up time is figured into the diesels delta RPM capability and is optimized for the diesel. ;)
It has been done, where there is a will there is a way and any obstacle can be overcome. Pier's has done this on the Cummins and the article is in these forums with pictures (supercharged twin turbo I believe) ;) .
The guy says he does Furd, Maxi's and Cummins in the ebay add.
The point AKAMAC is trying to make, is that the 7. 3 was only produced from 94-early03 not through 05 as this person claims.
Later,
Wes
SMDiesel.com
Later,
Wes
SMDiesel.com
Thank you Wes!
Gary a few production 7. 3's were put into early MY 04's 650's. I belive that they were stock displacement build. Much like the 03 7. 3's that live today.
The reason for my post was the picture in the "ad" was a 7. 3 and he advertised use in the 6. 0 by inclusion of later MY vehicles. I just thought it funny that he used MY "2005" as being a 7. 3... ... . My humor was lost and I apologize. Mike
" My humor was lost and I apologize. Mike"
Nah Mike - it wasn't lost - it's just that the statement you referred to had so MANY questionable areas, it as hard to know which ONE to focus on! :-laf :-laf
interesting ready esp this sig... sounds like alot of $$??
'99. 5PrairieTan/XLT/4x4/CC/SWB/7. 3,6 position DI chip , DI MM530 single shots, DI/Racor CCV mod. , DI switchable IDM, SP EBP sensor elim. , Zoodad mod. , AFE stage 2 w/ PG7, Suncoast Proloc T/C /Transgo kit, Garrett GT38r BB w/1. 15 housing, gutted EBV, DI H/X mod. harpoon mod, DI prepump & tank mod. , DI external fuel reg kit, DI/SX fuel feed w/ sump, Airdog fuel preporator, Autometer sport comp w/ A-pillar, Hog 4/4/5 ss straight-thru exhaust, 4. 56 gears, Sony/Alpine/Fosgate tunes, Delphi Skyfi XM, remotestart,'05 Headlights/Grill/Bumper,'05 Badges, britebox/silverstars,'05 heated/signal TT mirrors, 8"Fabtech, Bilstein 5150s, ORU crossover steering, ORU trackbar kit, Superlift, Truspeed, 20x10 Eagle 114 on 37x14 Nitto Terra Grapplers, ss brakelines, RCD trackbars
Bob
