OK... got my block heater cord from Cummins same day. Now I need your help again
Installed it with nut loose on cord. Plugged it in. It worked great. My block above the heater went from 21F to 75F in a couple hours.
This am it was 10F. Plugged her in for about a half hour, then went under (laying on carboard in snow
) and tried to tighten the cord nut with a small wrench I bought last night. Barely got 1/8th turn and noticed the heater fitting was turning too. The fitting going into the block looks like it was installed with white vinyl tape? Maybe the heater loosened it up. I could turn it by hand.
No noticeable anti-freeze leak yet.
Since I dont know what the heater looks like inside the block I have a couple question for the experts here.
1) Is it safe to crank down that block fitting until it stops turning?
2) Will I damage anything turning it?
3) Can the cord plug go into the fitting either way (180 off)?
(A picture of the actual block heater parts would be extremely helpful
Thanx for any and all advice you can give.
Joe
Joe
