I had my transmission worked on a few months ago at a shop. They installed a Suncoast converter and flexplate with the reworked transmission. After about 2000 miles, the converter bolts came loose and were allowing the converter and flexplate to rattle back and forth. I didn't notice this until I pulled off the highway after a 4 hour run, by then the holes in the flxplate had opened up to a point that replacement was in order. I tightened them up on the side of the road and finished the trip home. The shop that did the work initially installed another flexplate at no charge.
Now... the thing is, I drive the truck 300 miles and the bolts are lose and knocking again!! Has anyone had a similar problem?? I'd like to know if any of you have had your converter bolts come loose and what the particulars were. This time I caught it sooner before as much damage had occurred. I retorqued the bolts myself to 40ftlbs and they all needed to spin anywhere from 3/4 to 1. 5 turns to achieve that amount.
Thanks,
Hank
Thanks,
Hank
