This morning I fired up the truck and the power steering pump was howling pretty bad.
Best way I can discribe is like on a Bobcat when you have the engine at low RPMs and you turn start driving and it kinda "howls/whines".
I figured it was just cause it was cold, but the noise never really went away on my trip to work (12 miles).
On the way home this evening, I had limited power steering and brakes, and if I pushed the brakes and turned at the same time, I loose all power.
I checked the fluid and it was full of bubbles to the point where it was foam. I let it sit and just checked it and it's full.
Ideas? New Pump??
Ideas? New Pump??
