Hey on my 02 cummins 6speed, when I let it set for like an hour, I go to start it and it will start fine but it blows out a big puff of white smoke and the engine sounds like when you are bleeding the injectors (that real loud dieseling sound) I got a raptor 150 feeding 18psi to the injection pump last time I checked. No codes. Im thinking that its somehow bleeding the fuel back. I really can''t think strait right now because I really can't be having my truck running like **** right now. After you run it for a while it runs fine and starts fine. Ive pulled the fuel filter out and check it and the oring, they are fine but Im gonna change them anyways tomorrow since its cheap. I have change the banjo bolt on the vp44 supply line with a normal one and new washer seals (the old one had the schrader valve wanted to eliminate that just incase). The only thing I can think of right now is either connector tube orings or injector orings. There are no fuel leaks, Im thinking that somewhere air is getting in, I will hook up a gauge tomorrow and see what happens when I start it and it acts up. No codes, reman injeciton pump at 85000 truck has 93000 on it.
Any thoughts would help,
thanks
mopar
thanks
mopar
