Lorenz +26% vs 988's with a Camper
Best prices for Interior parts?
Checking steering gearbox
I have a 1800lb camper and may put on an ARB bumper with a winch at some point. I'm considering the Lorenz +26% coils but I'm not sure they are stiff enough if I have both the camper and a winch. The 988's will also supply a 11/2 inch lift, so either set up will level the front a bit. It appears the 988's are stiffer.
Has anyone put both a camper and winch on these springs?
I put and ARB bumper on the front of the 01 with old single rate KORE springs. I can't tell any difference in ride or ride height. The ARB isn't all that heavy. I'd think the Lorenz springs would be fine.
I'm running his 23% front coils with the 2. 25 SAW setup. My camper weighs 2000#. They're perfect for my application. You're going to need a complete system from somebody to dial it in. Shocks and valving make a big difference. I'd call up Sean,Carli,Thuren for some opinons.
I dont have exactly what you are looking for but it might help. This is with Lorenz IR coils and an extra 750ish hanging off the front, and 1200lb in the bed.
Thanks for the info
The posts gave me the info. I was hoping for. The photo also helped visualize it. That's more weight than I'll have on the front. I'll give them a call.
