Losing my mind with suspension pops and clicks
worst programer ?
Hydroboost hardline part number?
AMink
I'm about at my wits end with my front end. It tracks well, tires wear well, but there are just these barely noticeable pops/clicks that I can feel through the wheel and floorboards. This happens on any surface, but not all the time. I have replaced the shocks (Bilsteins), steering box, tie rod ends, sway bar links, sway bar bushings, Pitman arm, u-joint/stub shafts, and drive line u-joints. I have a steering box brace. It was just in the shop (they did the wheel u-joints) and they said everything was tight including the steering shaft. The only thing left that I can think of are the control arm bushings. Am I missing anything else that would cause the "loose" feel? It's like something should be *just* a little bit tighter. #@$%!
