HI all,
As some of you know I had my vp44 and transfer pump replaced (waranty). Aince then I have not retapped pump wire ( which is killing me) And have noticed mileage dropping from about 5something a tank to around 400 or so. Is it because of pump wire ,bad torque converter or someone siphoning diesel from my tank?Also the FP guage bounces around on the highway alot At idle it is steady at 15 but cruising it is 10 or so then it will drop to 5 then above10 and back and forth. is it normal or a bad sending unit , sending unit is attached to motor.
Thanks,
Marc
Thanks,
Marc
