Engine/Transmission (1998.5 - 2002) Loss of power at highway speeds
Engine/Transmission (1998.5 - 2002) 99 with 53 block blown
02 model going down the highway i get a loss of power, engine does not die just can't get any power out of her. , about 15 to 20 seconds later it will respond. If i am trying to give it throttle nothing happens and then all of a sudden it will rev up in response to the throttle location and get going again. I will be lookinf thru past posts in the mean time . Thanks in advance for any help
have you got the codes ? Codes can be accessed by Key on,off,on,off,on,off ,then leave on. Codes will appear in odometer window. Write them down if there are any,and post them here. Apps 0121,0122. ,injection pump has several 0216 is a common one. Hope this helps.
Yeah, need to see if there are any codes. How many miles, how long have u owned it? Auto - stick, any mods . . . . ? ? ? ? More data is good = we can better help you.
Create signature so you don't have to repeat yor self all the time and we don't have to ask as well. The more info we have the better we (sometimes) can help.
