I have a 96. the other day, the brake got very hard to push. Brakes still worked, just took major push to move the pedel. At the same time, the AC unit stoped going from defrost to vent to floor etc. It happened to be the defrost location where the AC came out. I don't know if this is a reture if vaccum is lost, or just where it was when I lost vaccum.
Since then, I've found the vaccum pump in front of the power stearing pump. I've traced the lines and found no place where it looks like the hoses are abraded. But some of the lines are under the firewall and dash. I assume there is a check valve after the brake booster so if I loose vaccum in the dash, the booster still works.
I don't want to pull out that pump if I dont' have to. Can anyone offer a suggestion where to look for a vaccum leak?
Since that day, it works fine. I assume as I as pushed and wiggled hoses, the leak sealed. However I know it's only a matter of time unitl it comes back.
Thanks for the help... ... ... ... ... ...
