I took the advice offered on the earlier post and removed everthing including the transfer case, but have not removed the transmission yet. In the bottom of the transfer case I found a broken set screw that came from the fifth gear nut. The nut 'appears' to be tight but I do not have the special tools the manual calls for. As everthing appeared to be ok I put the shifter back in and am now able to shift all gears like it used to... ... ... . All I did was remove the transfer case and now you can shift it. Why is that?
Fifth gear was replaced two years ago by the dealer on my 95.
Do I still need to remove the transmission to inspect the shift cover as I have not found anything that would cause me not to be able to shift into 5th/reverse with the transfer case attached?
Any and all advice is appreciated, Tom/Idaho
