My 96 3500 with 136,000 mi just lost 5th Just as the big work season is starting. I would suspect that the nut backed off it was like it just went into nuetral. I drove it for a couple hundred miles.
Anyway does the transmission have to be out to get at the shaft and nut. Is the shaft usually trashed with metal floating around. Or should I pull it and install the upgrade shaft and nut with a rebuild kit? I would guess the later. I am mechanically inclined Is this rebuild easy?? Any help would be apreciated
