Archived Lost Brakes!!!
Archived 03 Clutch Slave Cylinder lost fluid
Archived 95 TPS Throttle control part source
While backing into my spot at work last night the brake pedal completely froze. Kind of like somebody welded it solid. I also discovered that the Exhaust Brake no longer worked. The brake light was on as well as the ABS light. I went back out when I had a little bit of time and started it up. Still the same with no E-Brake. Looked under the hood for a disconnected or broken vacuum line but couldn't find anything. After a while the E-Brake started working again. When I left worked the ABS and brake light came on when I was idling various stops. The E-Brake still worked, and the brakes functioned. When I got to the shop where I do all my work it was working fine. No lights at idle and I couldn't duplicate the solid pedal. Hooked up the Vacuum gauge and had 26in/hg @ idle. Is it a good indicator that my Vacuum pump is on its way out? I know they are expensive, and I think I have seen something about rebuild kits on here. I have to search around. I will test it again later when it is cold. Truck has 190,500 miles on it.
thomas
After spending an hour or two searching the old threads I think I have it figured out. I guess I could have searched around first eh!! Thanks anyway.
thomas
