Lost OD and TC lockup
Missed out on my dream truck
Houston alignment shop
I have a 96 C/C 4x4 AT. Tonight when I left work the transmission wouldn't shift into overdrive or lockup the TC. The only thing significant that happened between this morning and evening was a 30 minute hurricane of a thunderstorm but I don't think it has anything to do with the problem.
I was able to get the transmission to shift three times in the 22 mile drive but had to accelerate to 2500 RPMs in third. When I backed off, it shifted. A moment later the TC locked up. As soon as I decelerated to 50 mph, it unlocked then shifted down. Lather, rinse, repeat times three.
I initially thought it might be a pressure-related problem but the factory manual led me to check the TPS. I adjusted the idle up some, checked linkage length, and got .8 VDC at idle position and 3.05 VDC at WOT--all in spec.
I decided to check codes after that (should have done that first). It threw a P0123 for TPS voltage. Since I did get a funny read of 5.8 VDC at one point during the test I assumed I had crossed the shorting pin through to another terminal on the TPS connector instead of just the center one (assuming 5 VDC reference voltage?). I removed the test pin, cleared the code and then went for a test drive. I couldn't get it to shift even with the high revs this time and when I got back the P0123 code was back.
Since the TPS checked good I'm hesitant to replace it based solely on a code. Has anyone else seen this problem and if so, what was the fix?
I bought the new TPS but decided to test drive again before I changed it...glad I did. It's working fine again. I cleared the code and drove it again. No code. Did several idle to WOT exercises with ignition on and engine off. No codes. I'm going to carry the sensor in the truck for a week or so and see what happens. I'll probably order the potentiometer kit off eBay in the mean time as a backup.
