Left my '95 5spd 2wd parked facing uphill (a no-no, I know) with a quarter tank of fuel (also a no-no, I know) for a week, just went to move it yesterday and it won't start. Replaced ff 2,000 miles ago.
Two years ago I had similar problems starting, so I replaced the supply/return "rubber" lines at the fire wall with the kit from Larry B. Which worked just fine until yesterday.
Fuel shutoff solenoid it not retracting on it's own (coincidence or not?), but I've been pulling it up manually before cranking (yes, after I've turned and left the the ignition in the "on" position).
Usually when I park on an incline and have a hard time starting, I can push the primer on the lift pump, crank it, prime it etc... and eventually it'll start. Been trying for two days now, drained the batteries dead and still nothing.
So, from what I've been reading on the forum it sounds like I'm not even getting fuel to the fuel filter, since I don't feel or hear any fuel passing when I push the primer (at least 40-50 times).
Are there quick and easy points to disconnect the fuel lines from the tank and drop in a bucket of fuel, then priming and see if fuel gets to the filter that way, or... ?
Any other thoughts or suggestions? Cracking injectors?
