Engine/Transmission (1998.5 - 2002) Lost RPM`s overnite?
Engine/Transmission (1998.5 - 2002) transmission Temps...problems??
Engine/Transmission (1998.5 - 2002) Will this cause any black smoke?
Went from 3400 rpm`s to 2900 overnite. checked and changed both fuel filters and cleaned air filter. has just an EZ and a set of injectors. please give me some things to check, there are no codes!
You don't happen to have a high idler from practical solutions? I've accidentally bumped mine and barely turned it on. I had a dramatic loss of power, I almost :{ when it happened, but then I figured it out. It's almost like a valet switch for a 24v.
Corey
C/A !! you are the MAN. Yes I do have a P/S high idler and YES it was just barley on. thanx for your insight. Your ears must have been burning to know that I had a P/ s idler, thanx again
SWEET. :cool: Glad I could help out, I felt the same way you did when it happened to me. :confused: Then I figured it out, kinda takes a load off when you think something is majorly wrong with your truck and then it's something simple.
Corey
