The relief valve is really called a overflow valve & stretching is for helping to making run better on the way to the parts house , it will not last , needs to be new .
But 1st up is testing , fuel pressure test , about 25 psi idle , 36 at WOT , if not pinch return line to see if pressure comes up , if it does then overflow valve , if not lift pump , then after test again , may need OFV also .
