JFaughn said:I heard that one of the air filter mods require a hole in the firewall as part of making it work and this makes for your listening pleasure.
PATRIOT_Ram said:Take the silencer ring out of the intake side of the turbo. Also take the baffles out of the plastic tube between the two elbows on the intake pipe.
silverram03 said:The only way you will ever get your truck to sound like a 6. 0 liter is to buy one as they have a variable geometry turbo set up. I think the 6. 0's sound the best when the are first started up, kinda like a jet engine coming up to speed.
CTD 600 said:I'll stick with DC. Is there a possibility of having a variable geometry turbo made for the Cummins? What are the advantages of having those kinds of turbo's? Disadvantages?
Matt400 said:You could go out to an Air Force base, take a sound clip from a C5A Galaxy on take off then play it through your speakers. That should shake your 6. 0 friends up. :--)
