Just finished installing the finial 2 gauges Boost & FP. Good new is fuel pressure is 12lbs idle and 10 @ 65, bad news boost is low @ 65 is was 5lbs. If I down shifted, run it up to about 2400rpm it reached 20 just for a split second then dropped real fast. It does not seem to make any boost under 2000rpm. I have alway felt this truck had high EGT, I can get the EGT to 1000 under acceleration just getting on the FWY not towing.
Now I live at 7000 ft, but should the boost be this low.
Thanks in advance
Jim
Thanks in advance
Jim
