01', Goerend transmission, Fass 150, Juice with Attitude, 180k miles
Just got back to Texas from Kansas with a load of hay, weighed 34k, fass 150 usually runs 15 to 16 and I could never pull it below 12, now it runs 14 to 15 and I pulled it down to 9 on some big hills, used to at times, on big hills get 32lbs of boost, today the max was 24, seemed like possibly my EGT's were a little higher than normal running 1,000 to 1,350 degrees, had the Jucie on #1, #2 and #3 with no real noticeable difference in the above readings
Is my turbo going? Is this an air issue or a fuel issue? where should I start, truck has been running fine, this is my first trip loaded in awhile this heavy,
any help & thoughts would be appreciated, no leaks, engine and transmission temps were fine
thanks in advance!
thanks in advance!
