Problem has progressed over the last few weeks. After searching the forums i haven't found a likely cause. I used to be wastegated to 35 psi boost. Now i can hardly get into the mid 20s.
Used to see over 1,500 EGTs. Now i don't get to 1,400. During almost every acceleration EGTs climb above 900 degrees. Power is abrubptly cut off in the upper RPMs. Feels suddenly choked.
Smoke is about the same. Even under less throttle the engine feels less responsive, less powerful. Almost as if the cam plate has been changed to defuel on top, but it was most recently custom ground and slid all the way forward, as was the AFC. No engine tuning in over 2 months so i don't know what might have moved or changed.
I've sprayed starting fluid around the intercooler boots and the idle only raised when sprayed at the air filter. I previously noticed that when at low RPMs and boost while trying to accelerate hard, the throttle pedal was very stiff, hard to depress, heavy smoke. This problem is no longer present. Could the issue be with the AFC, wastegate, or GSK? Where should i begin?
