It should come on then go out when the pump cycles on, and will usually come back on after a few seconds with the engine off. The pressure switch should complete the ground for the light circuit. Touch the wire that goes to the pressure switch to a ground and see if it lights up. Where do you have the switch mounted?
Matt
