I just got my fuel pressure gauge hooked up again, and notice in the morning when the truck is cold around 30 deg. I only have 0-2psi for about a . 5 mile, then goes to 5-10psi for about 1mile, then goes to normal at 12-14psi. I've seen this for the last three days, and only happens in the morning or after the truck has sit for more than 5hrs. Has anyone else had this problem? Do you think it's lift pump going bad, or is the ecm cutting power to the pump for the first coulpe of miles? It works fine the rest of the time 14psi@idle, 11-12psi@cruise, and 6psi@WOT. Also is this hurting the VP44 I only drive light throttle until teh pressure comes up. Thanks in advance I hope to find the problem before it ruins something expense.
Thanks,
Matt
Thanks,
Matt
