Ok. I've tried two new stock lift pumps, changed the fuel filter, calibrated the fuel pressure sending unit and gauge,changed the overflow valve and checked pressure readings at the lift pump (12psi idle)and injection pump (11psi idle,5psi WOT no load). Any ideas as to what the problem may be???
Thanks
Thanks
