Low Fuel Warning Light Disable
transmission no unlock, might be the computer!
Rear end oil question..DANA 80
Group- I long ago gave up on my fuel gauge and have been using my odometer. The darn low fuel warning lamp is on almost continuously and is very annoying. Is there an easy way to disable it. TIA
1995 2500 Auto 4X4 Ext Cab, Sun Coast torque converter, Trans Go shift kit,Jacobs E brake,BD Auto Lok,Prime Lok fuel filter relocate, Boost/EGT and transmission fluid temp gauges, and Mag-Hytec transmission pan/rear end covers
Easy, just remove the trim from the dash panel by removing the four screws(2 on cupholder and two on ashtray) and pull it off. Then unscrew the cluster and tilt it out and pull out the bulb for the fuel light by turning it 1/4 turn and pulling it out. Ten minute job, instant satisfaction. #ad
Chris
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc. Test mule for Auto Wurks race program
