Low Idle
another from a bio beginner
bio in NJ
My trucks idle was set around 800-850, I ran a batch of vegetable oil in it yesterday fro the first time(I mixed everything properly) now my idle is around 200 rpm lower(650) I changed my fuel filter around 5k ago, should I change it again, thanks for any information, Alex (93W-250 5SPD)
filter ?
hello
try changing your filter was the tank realy low if so you got all the crud off the botttom of the tank hope this helps
fuel filter should be man made not paper inside vegoil makes paper swell up and cuts the flow of fuel make sure it a poly webbing of some sort
the 3rd gen filters or all ok for this 1st and 2nd gen's ?????
cj hall
