Archived Low Oil Pressure
Archived Truck won't start AGAIN!
Archived Injector install, now oil???
17k miles on 2005 3500. Oil pressure reads 40+ on initial startup. After warmup, pressure drops to 20 at idle and doesn't return to 40 until over 1500rpm. Just started doing this past week. Took it back to Dodge dealer and they said the factory specs were 10psi at idle-30psi at 2500rpm. Bull..... 10psi is in the middle of the "red" zone on the factory oil guage. It has always read 40-50psi until last week when the dealer changed the oil!! Any thoughts?
Thanks for the reply link. I'll put a mechanical guage on it and see what it says. I got concerned when it was always reading 40-55psi and then suddenly started reading low after warmup. What is the normal range I should see with a mechanical guage? I still can't believe the Dealer said 10-30psi!!
You may want to contact Cummins or a Cummins repair facility . Make reference to Cummins ISB that is the model motor for the Dodge. Let us know what they say.
Don
Unfortunately, what the dealer said is true, per the factory service manual on alldata, the specs at idle are minimum of 10 psi oil pressure.
