Engine/Transmission (1998.5 - 2002) Low oil pressure!!!
Engine/Transmission (1998.5 - 2002) enterprise valve springs
Engine/Transmission (1998.5 - 2002) Pulling Trans
Our 99 has low oil PSI only when its warm.
It reads 23PSI at idle and goes down to 18 PSI in gear, somtimes as low as 15.
In normal driving cond. it stays above 40PSI
And yes We are running a Fleetgaurd filter LF3959
What gives :confused:
Michael
Did you try using a gauge in the sensor hole to check to see if the sensor may be off ?
Next maybe some sluge in there , run a qt. of ATF for a coulple hundred miles before your next oil & filter change .
