Have a 97 3500 4wd 4:10 5 speed with 209k. no mods
The problem started with low power, no black smoke. so installed boost guage and can get 25 psi. check fuel pressure, was low 12 at idle max 20 at 2500rpm. I replaced the overflow valve as well as the filter, and cleaned the prescreen. fuel pressure came up 5 psi so max is at 25 psi.
with the engine warm, if I mash on the gas the engine will stumble and backfire?? (not sure if diesel can backfire) and a cloud of blue smoke will appear. If I ramp up quick to 2500rpm no problem and run very smooth.
so I have a fuel plate and gsk to install but wanted the truck to be running right before i proceed.
So I am looking for help on what to do/try next, everything looks good. no air leaks at the afc line, fuel lines look good as well, no cracks that I can find.
engine has no blow by, I don't think its whipped yet, so figure I missing something simple.
