Well the truck is still not running that great. I am going to try double check with the clear plastic fuel line just before the lift pump to see if I see any bubbles.
I am just confused as to the boost pressure. When the truck is running poorly on the freeway it will say 5 psi of boost on level ground or downhill at 72 MPH. When its running better that number is lower, maybe 2-4 psi.
I am not sure that bubbly fuel would do this? I am wondering if the previous note about a warn front bearing in the transmission is causing a drag on the engine.
I really don't want to pull the Getrag, because that also means pulling the NP205 but maybe I should??? Can I inspect the bearings in the trans without removing the transmission?.
